Reply
Highlighted
Follower
RBR50 / RBS50 Firmware Version 2.3.1.44
Ever since update, google home hub can't connect to wifi. Tried factory reset. When it comes to join network, can't see network. Google home and google mini are fine.
Message 1 of 3
Highlighted
Guru
Re: RBR50 / RBS50 Firmware Version 2.3.1.44
Ensure the home hub device is up to date on FW.
Doesn't see any SSID coming from the Orbi system?
What WPA security modes are you using? Try WPA2 and AES only.
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Contact Google about this device for additional help and information.
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK50 v2.7.0.70(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
Highlighted
Guru
Any progress on this?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 408 views
  • 0 kudos
  • 2 in conversation
Announcements
