Orbi WiFi 7 RBE973
Reply
RBR50 Ring staying Solid White
dc_iron
I have powered off and back on twice. I have hard reset twice. The Obri won't go past Solid White Ring. Try to access from the App but my phone, or computer, won't log onto the Orbi network. When I "forget" and re-join it tells me my password is incorrect. Please help
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Guru
Re: RBR50 Ring staying Solid White
Press the reset button in back for 15 seconds then release. Connect a wired PC to the back of the RBR and use a web browser and walk thru the setup wizard at 192.168.1.1.
Message 2 of 4
dc_iron
We are on Xfinity and the Orbi is hardwired to the Xfinifty cube router. My laptop does not have a network cable port.
Message 3 of 4
Mstrbig
Master
Then reset the router, reboot the ISP modem/router, plug the Orbi router into the ISP modem/router and use the app to configure it.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1584 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
