Orbi WiFi 7 RBE973
Reply
RBR50 Router Firmware Version V2.0.0.74
JaySix
Follower
The above update killed the Advanced option tab!
Now just have Basic...
Anyone else?
Thanks.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
tucsontico
Virtuoso
Re: RBR50 Router Firmware Version V2.0.0.74
I did not experience the loss of the "Advanced" tab. From what I see on this forum a NVRAM reset (don't have the exact instructions) and Factory Default Reset are the best things to do after the 2.0 upgrade. Do a basic setup and do NOT load in any saved settings from a saved configuation file.  Other users are also saying not to do any speedtests in the admin panel and to try disabling Daisy-Chain.  Good luck! https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 709 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
