- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 Slow Hard Wired Download Speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I test the speed through the Orbi App or logged in via orbilogin.com the download speeds are 460 to 470 mBs. On my mac hardwired through a Netgear 1GB switch and Cat 5e wire my download speeds max out at 270 mBs.
I am sure there is a setting that is reducing my speeds. I have turned off Guest Access.
Thank you in advance for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Slow Hard Wired Download Speeds
What is the Mfr and model# of the ethernet switch in the configuration?
Remove the switch from the mix and use a wired PC connected to the back of the RBR.
IF you have enabled any Access Controls, Traffic Meter on the RBR, you'll need to factory reset the RBR and setup from scratch. This time don't enable any AC, TM or Speedtest with in the RBR. Just setup the RBR, then run a speed test using Ooklas installable speed test app on your PC. CAT6 is recommended.
Test your wired PC out directly connected to the ISP modem as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried with Surface Book and MacBook Pro as well as phones that are gigabit internet capable. All devices are on 5ghz according to Orbi "connected devices list". Doesn't matter which device connected on wifi, all show download speed cut in half. However, if I plug any laptop directly into Orbi, download speed is at full 300mbps+. Something not right with wifi signal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Need more information then this.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@euidhawiojp12 wrote:Tried with Surface Book and MacBook Pro as well as phones that are gigabit internet capable. All devices are on 5ghz according to Orbi "connected devices list". Doesn't matter which device connected on wifi, all show download speed cut in half. However, if I plug any laptop directly into Orbi, download speed is at full 300mbps+. Something not right with wifi signal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried with Surface Book and MacBook Pro as well as phones that are gigabit internet capable. All devices are on 5ghz according to Orbi "connected devices list". Doesn't matter which device connected on wifi, all show download speed cut in half. However, if I plug any laptop directly into Orbi, download speed is at full 300mbps+. Something not right kodi lucky patcher nox with wifi signal.
