Orbi WiFi 7 RBE973
Reply
RBR50 (US Router w/3 Indoor Satellites Online) & RBS50Y Outdoor Satellite) will not Sync
Ruze69
Have a RBR50 + 3 Satellies Online and up for over 6 months.
Adding a RBS50Y Outdoor Satellite.
Syncing to Router unsuccessful. Even when located within the same room during Sync Process.
Factory resets, etc without success on the RBS50Y. Login on Router and all appears to be functioning for the rest of the system.
Please Advise!
RBR50 Router
3 - RBS50 Satellies
1 - RBS50Y Outdoor Satellite (unable to sync)
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 5
Accepted Solutions
Ruze69
Re: RBR50 (US Router w/3 Indoor Satellites Online) & RBS50Y Outdoor Satellite) will not Sync
Thank You for the reply.
I keep my RBR50 Firmware "Auto" updated in these times. But, I was unable to access the RBS50Y unit without a Ethernet connection.
I did find another obscure note while searching. Coincidence or not....
It recommended Multiple Power Button Cycling after a 60+ second reset.
It worked.... That is coincidence or Top Secret stuff! Lol!
The unit was used to replace a standard Satellite and is awesome! Highly recommended!
Thanks for the assistance Good Luck to all!
Message 4 of 5
All Replies
Guru
I would make sure the FW is up to date on the RBSY unit, then the unit should connect.
@Christian_R
Message 2 of 5
Christian_R
NETGEAR Employee Retired
Hello @Ruze69
Please let us know if @FURRYe38's recommendation solves your issue.
~Christian
Message 3 of 5
Ruze69
Message 4 of 5
Guru
Enjoy. Smiley Wink
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1103 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
