- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 WAN stuck at 100mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
My rbr50 Wan port will not see anything higher than 100mbps. After trying every cat6 cable in the house, I tested AP mode and borrowing another moder/router and plugging into any other lan port, I get the 300 or so I'm supposed to see. I tried the Mirror lan 1 and using lan 1, but that didn't work as I'd hoped. Any other ideas before I start shopping?
So I know the modem isn't the issue.
The cable isn't the issue.
I have tried this on the latest firmware.
Using the RBR50's built in speed test.
Is there anyway to force it to use 10/100/1000? A telnet command or something...? Everything else on this has met my needs and I would rather not have to replace it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 WAN stuck at 100mbps
Using the web interface, click Advanced tab and then click the "Show Statistics" button. Does this also show 100M/Full or does it show 1000M/Full for the WAN port?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time WAN 100M/Full 195413 226245 0 35082 88878 00:44:38 LAN 1 1000M/Full 233557 191774 0 28887 22924 00:44:30 LAN 2 1000M/Full 00:44:30 LAN 3 100M/Full 00:44:30 WLAN b/g/n 400M 32934 1733 0 240 65 00:43:58 WLAN a/n/ac 866M 340062 363229 0 27888 12565 00:43:53 WLAN Backhaul
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since you tested your cable and modem and verified they are working at gigabit speed with another modem, then your RBR50 may be defective. If it is still under warranty, then contact Netgear support for an RMA.
You might also try a factory reset to see if that corrects the issue. Save your configuration first so that you can restore it if needed, or at least take screenshots of each configuration screen that you customized settings on. NG support may also request you to factory reset it as part of their troubleshooting process before issuing you an RMA.
FYI, I subsribe to 100Mb/s speed from my ISP, but my WAN connection to my modem is 1000M/Full.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@stickx911 wrote:My rbr50 Wan port will not see anything higher than 100mbps. ..... and plugging into any other lan port
Maybe it would useful to know exactly which modem/router the Orbi is connected to (brand and model number). With more than one LAN port, it sounds like this is a router. (A topic for a different discussion.)
Frankly, I was a bit surprised to read what goes into gigabit ethernet autonegotiation:
http://www.ethermanage.com/ethernet/pdf/dell-auto-neg.pdf This is WAY more complicated than I had expected.
It might be useful to look up the specs on the ISP device to see what it says about the LAN port standards.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for all the feedback! I was hesitant to do a wipe as I have a lot of things configured, but I suppose it's worth it before giving up all hope.
Issue started (was first noticed) on a sb6183 and getting 300mbps plan last year. I always had ~50 before, so it wasn't a consern prior to. xfinity claimed it was because of docsis 3.0 so last month I bought a sb8200. Same results. xfinity came back and spent hours checking the cable lines and such before hooking up their xb6 combo modem/router and it worked.
I don't trust the cable company as I've had them pull these tricks on me before so I spent a day or so trying every manageable combonation and the only way orbi sees 300mbps internet is in ap mode using a different LAN port on the orbi instead of WAN. Can't use AP mode on the sb modems.
I do not want to use the cable companys system because I like having a lot more control over my network. Extra fees kinda sucks too. Idk.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@stickx911 wrote:Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time WAN 100M/Full 195413 226245 0 35082 88878 00:44:38 LAN 1 1000M/Full 233557 191774 0 28887 22924 00:44:30 LAN 2 1000M/Full 00:44:30 LAN 3 100M/Full 00:44:30 WLAN b/g/n 400M 32934 1733 0 240 65 00:43:58 WLAN a/n/ac 866M 340062 363229 0 27888 12565 00:43:53 WLAN Backhaul
This seems very odd that WAN port is doing 100Mbps and LAN 3 is doing 100Mbps. Just curious, remove cable from LAN 3, swap the cable connected to WAN port with the cable connected to LAN 1 or LAN 2 to see if WAN port changes to 1000Mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
04:02:49 Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time WAN Link Down 1612924 2581838 0 0 0 00:00:00 LAN 1 1000M/Full 2920615 2325685 0 239661 54486 04:02:09 LAN 2 1000M/Full 04:02:09 LAN 3 1000M/Full 00:00:31 WLAN b/g/n 400M 571098 342553 0 6868 3427 04:01:37 WLAN a/n/ac 866M 1302159 1396071 0 47416 9166 04:01:32 WLAN Backhaul 1733M 239256 91964 0 1861 1502 04:01:32
moving the modem to port 3. same cable as was reading at 100 before.
3 was just a cheap POE camera setup with 10/100 (an IP camera switch). I removed it entirely here to at least test to see if it was bringing it down. That device also just shows 100 no matter what it's plugged into, but I'm pretty sure that one just doesnt have gigabit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you reconnect to WAN port (without the cheap POE connected to LAN 3) and it still says 100Mbps on the WAN port, I would find a paper clip and do hard reset, stick it in the back until it blinks amber. Don't restore old config after reset!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@stickx911 wrote:I don't trust the cable company as I've had them pull these tricks on me before so I spent a day or so trying every manageable combonation and the only way orbi sees 300mbps internet is in ap mode using a different LAN port on the orbi instead of WAN. Can't use AP mode on the sb modems. .
The Arris Surfboard 8200 is a "modem", not a "router/modem". So, it does not act as a DHCP server, handing out IP addresses. This means the Orbi must be in "router" mode for any devices connected to the Orbi to function. The WAN (yellow) port on the Orbi is the only port that should be connected to the 8200. If the link does not come up as 1000 Full, then you have to (a) try a Factory Reset, and if it fails to fix the situation, (b) contact Netgear for a replacement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
