- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 WIth FW 2.3.5.30 Dropping Conection all the time
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the RBR50 and RBS40 and RBS30 Satlites , My Wan is a Point to point Airfiber contection this has been flawless for months , Now with this new Firmware I have to constantly reboot the Router because it loses conection to the Wan this is just redicoulus can anyone assist I need to get a new firmware or do back down to the older firmware ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 WIth FW 2.3.5.30 Dropping Conection all the time
Try a factory reset and setup from scratch before downgrading FW.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nice caned responce
System has been flawless untill 2.3.5.30 .. Thats the issue here not my setup , I have reset it and I have the same issues , I am a Large Netgear Reseller I would never recomed this system to anyone because of the constant pain when you people break your firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Then downgrade FW.
Questions are for us so we can get a better idea of the situation. Not everyone has the same configurations. If you don't give feedback then it's hard or anyone to help you.
V30 has been working for others as well. Mines currently loaded since v30 appeared. Zero issues.
If your a NG reseller then maybe you should find more official NG support lines.
Good Luck.
