- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50. Wi-Fi signal dropping
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Wi-Fi signal has been dropping a few times a day for a few minutes . We have been using it much more heavily the last 2 weeks . It usually self heals in a few minutes . Occasionally it does not come back and I need to reset the Orbi devices
II have 400 MB/s internet coming in. Is it possible that there is a problem with the number of concurrent devices , we can have 8 to 15 devices logged in
any thoughts ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50. Wi-Fi signal dropping
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Has a factory reset and setup from scratch been performed since last FW update? If not, try this...
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:What Firmware version is currently loaded?
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
You could simplify this by only asking What Firmware version is currently loaded?
