Reply
RBR50 & RBS50 Firmware will not update
pwgerardi
I have an Orbi RBR50/RBS50 that is stuck on firmeware version 1.4.0.18. Everytime I check for updates it says current.  Tried to manually do update and no success. I tried going to go in succession to 1.4.0.34 then tried other versions of 1.xx then tried the 2.x with no luck every time I try to upload the file it comes back with Filename incorrect, use the correct file. I am trying to do satellite first as per instructions.  Anyone have any suggestions?
Thanks
Message 1 of 8
Guru
Re: RBR50 & RBS50 Firmware will not update
Please download v2.0.0.74 for the RBR and RBS. Update the RBS first, then update the RBR to v2.0.0.74 lastly. After that you can apply v60 to the RBS. You may need v212 for the RBR first then v60. Use a wired PC to do this update process.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 8
pwgerardi
Thanks for replying, tried that & will not work no matter which version I try.  I am using a Mac, des that matter?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 3 of 8
Guru
v2.0.0.74 should work. Be sure you use Safari or Firefox browsers. Factory reset both RBS and RBR. You can update the RBS first with out conneting it to the RBR with a wired PC/Mac. Wire connecrt a PC to the RBS and wait for the PC to get an IP address. Log in to the RBS web page at 192.168.1.250. Log in admin and PW is password.
Mac shouldn't be a factor however if you have a windows PC, please try IE11 or FF browser there.
Be sure your unpacking the .zip files to reveal the actual FW update file.
Message 4 of 8
pwgerardi
Still the same reponse, was using Chrome but tried with Firefox same results: Filrmware filename incorrect
Message 5 of 8
CrimpOn
Guru
What is the file name?   It is supposed to be something like: RBR50-V2.3.1.60.img (this the latest one I downloaded)
I love my Orbi.
Message 6 of 8
pwgerardi
Latest I tried was RBS50-V2.0.0.74.img
Message 7 of 8
Guru
I would make contact with NG support...
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1774 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
