Orbi WiFi 7 RBE973
Reply
RBR50 as AP speed cap
leforban
Hi,
It has now been a few days, my down and up speeds are limited to 24Mbps.
I tried to downgrade the firmware from 2.7.2.104 to 2.7.2.102 but it didn't make any difference.
When plugging an AP to the same cable I get 60 Mbps.
I'm using an RBR50 and RBS50 in AP mode. 2.4 and 5Ghz broadcast. 100% transmit power. CTS/RTS 2347. Beamforming, Mu-Mimo and Fast Roaming on.
Any idea what's wrong ?
Thx !
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Accepted Solutions
leforban
Re: RBR50 as AP speed cap
Hey thank you for your answer.
I just resetted the thing and everything is back to normal !
300 down and 20 up 😉
Thanks
Message 3 of 3
All Replies
tak1313
Luminary
If you don't have older legacy devices, turn off 20/40 Mhz coexistence (if you have it on).  It can slow your wirelss speeds significantly and most people don't need it anymore.
Message 2 of 3
leforban
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 589 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
