- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 - can't connect to primary network, only to guest
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the Orbi RBR50 router and one satellite. Since the initial setup (>90 days ago), all my devices except an old Lenovo laptop could connect to both the primary and guest WiFi networks. I thought it was just because the laptop was old and didn't have time to troubleshoot it. I have a newer HP desktop connected via Ethernet only (interestingly, it says it's connected by Ethernet to the guest network SSID). Now I realize that my newer HP desktop also cannot connect to the primary WiFi network, but can connect to the guest WiFi network. I've searched online a few times for people having similar problems but have not found solutions. Orbi support says I'm past the 90-day window to get help from them.
Anyone have suggestions on how I can fix this? I'd like to have all my home computers (desktop/laptop) and printers on the same WiFi network. Other devices can connect to both primary and guest WiFi (phones, Echo, Roku, etc) without issue.
Thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for responding. I answered your questions below and changed settings as you advised, then rebooted the router and satellite. I was still not able to connect to the primary WiFi network at first, but after "forgetting" it on both laptop and desktop, I am now able to do so. (I had tried forgetting all WiFi networks before making any orbi router changes and it never worked.)
I am not sure which setting did the trick, but I appreciate your advice!
V2.3.5.30
Through Comcast/Xfinity
TECHNICOLOR CGM4140COM
2200 SF
About 50 feet. I remember the blue ring when I first set it up, but now I don't see any color.
2.4Ghz - auto
5Ghz - 48
I set 2.4Ghz to 01 for now.
Yes, I see 6 other WiFi networks.
- Done
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
-Done
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 - can't connect to primary network, only to guest
Disable Guest Network on the Orbi and test wifi devices.
Disable WPA security temporarily on the RBR. Does your two laptops connect then to the RBR? Re-enable WPA2 and AES on the RBR after testing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@menreeq wrote:I have a newer HP desktop connected via Ethernet only (interestingly, it says it's connected by Ethernet to the guest network SSID).
I have noticed that my Lenovo Windows 10 laptop gives a similar report when connected by ethernet, only it shows the primary WiFi network name. (I do not have Guest activated.) My desktop Windows 10 machine says only "ethernet", because I have the old WiFi adapter disabled.
Would there happen to be any special or unusual characters in the primary WiFi name and/or password?
- Mark as New
- Bookmark
- Subscribe
- Permalink
V2.3.5.30
2200 SF
2.4Ghz - auto
5Ghz - 48
- Done
-Done
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Sounds like it was the forget network that was the fix.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
