- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 constantly dropping of wireless connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good afternoon,
i'm out of options
i have an orbi rbr50 with 3 satellites. my house is 250m², i think that's about 800square foot, two floors.
Since the start (about a month ago) my wireless network is dropping every ten minutes, and coming back online a few minutes later, practically unusable for the bussiness i'm running.
my isp is rock stable since i have one computer lan'ed to it and it doenst miss a beat.
i have tried: turning off daisy chain, mu-mimo, armor, circle.. and all the rest advised here on the forums.
i've had my isp place another router, so i could bridge it
i've downgraded firmware, reupgraded firmware and did about 15 factory resets after it
before the router change and the isp router in "bridge", i tried putting it in ap-mode: same thing
nothing works .. it's fine for one day each time, second day the drops are coming back occasionally, by the end of day two my wireless network is as much off as on.
phone support was .. not-supportive, promising me to get a callback by "specialists", but still waiting on it.
does anyone please have any other ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 constantly dropping of wireless connection
More info is required....
Modem type/model?
Orbi firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
current firmware is 2.5.1.8 but i have tried 2.3.5.30, same results
my isp router is a compal cv8560E, in bridge mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
lots of discussion about bridge mode in the search section.
try this:
- Mark as New
- Bookmark
- Subscribe
- Permalink
my isp router is in bridge mode, my orbi is in normal router mode.
before this setup i tried with the isp router normally, and the orbi in both router mode and ap mode, both gave the same frequent disconnects
- Mark as New
- Bookmark
- Subscribe
- Permalink
you may want to start over. there are know issues with the .18 fw version.
does the compal cv8560E have wifi built in? if it does, and you need to use it, then either the orbi or the compal cv8560E will need to be in the AP mode. Not both.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I actually have started over, I downgraded to v30 firmware, had same problems, re-upgraded to the .18 fw and still having same issues.
the compal is bridged, the orbi is in router mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
if you don't need the compal, try setup without it, placing the Orbi in router mode.
otherwise try this:
https://kb.netgear.com/30186/What-is-Double-NAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since your modem is in bridge mode already, then Router mode is needed on the RBR. There is not double NAT in this condition. This would not be a cause of your wireless problems.
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
Has a factory reset and setup from scratch been performed since last FW update on v2.5.1.8?
@dentnvr6 wrote:current firmware is 2.5.1.8 but i have tried 2.3.5.30, same results
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
thx for the suggestion, although my setup is already as described.
after each major change (including fw down-or upgrades), i always do a complete factory reset.
i also tried wired backhaul this weekend, but again: after about 24h disconnects start happening more and more often.
- Mark as New
- Bookmark
- Subscribe
- Permalink
the isp router is bridged to the mac adress of the orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the RBS directly wired to the back of the RBR or is there LAN switch in between? If so, What is the Mfr and model# of the ethernet switch in the configuration?
Any other wifi devices that you have that are broadcasting a signal?
Try some of the suggestions please.
@dentnvr6 wrote:thx for the suggestion, although my setup is already as described.
- Mark as New
- Bookmark
- Subscribe
- Permalink
they are connected through a netgear GS108GE, nothing else is broathcasting a signal.
there is no difference in behaviour between wired and wireless backhaul: 14h no issues, then slowly more till it's all the time.
I have also tried with only one satellite instead of three, was the same (tried two different satellites).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have no throttling issues, all speeds are exactly as advertised (main reason i didn't bring this back yet)
but i will try with only the RBR, most RBS are about 30 feet away
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you confirm the model# of the switch again? GS108GE or maybe a PE?
- Mark as New
- Bookmark
- Subscribe
- Permalink
this is the exact model:
https://www.coolblue.be/nl/product/90250/netgear-gs108.html
i've tried turning off all satellites and am now in the happy first 24h where it always goes well.
I remember reading something about putting a timer on the satellites because there was an issue in an older fw version? would this be a possible cause of my problems? the fact the first 24h are problemfree, and then it slowly become worse all the time, tends to give me the impression i might be suffering from this? I just don't want to spend the money on three timers to find out this isn't the cause either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok just wanted to see if your switch was managed or has any green ethernet. These can cause problems.
So with all RBS turned OFF, the RBR along the wifi is stable going back 24hr?
What happens if you turn on just 1 RBS with the RBR. Test this configuration past 24hr.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately it wasn't stable either, all wireless received "verification error"
the distance normally between router and satelleties is approx 8m (25feet), but i have tried placing further and closer. both didn't change the behaviour of the drops.
so i'm back to zero. any other suggestions I can try?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can try downgrading to v30 on the RBR, factory reset and setup and test. If this still fails, possible that the RBR is faulty and needs to replaced or RMAd.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have tried downgrading to V30. although i did not do a factory reset afterwards.
I did however do a factory reset after upgrading afterwards again to latest version.
both times same result: a bit less than a day okay, then deteriorating
but i will try downgrading again and do a factory reset afterwards. or should i try another fw?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try v30 with a reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
loaded v30, did a factory reset,
using manual channel 1, wifi nearby yes, about 3 but low frequency.
beamforming, WMM and mimo enabled
everything disabled , coexistence is off, and short preamble set.
rebooting atm, fingers crossed, guess this is last shot before i return it and change.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, let us now how it turns out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
