Orbi WiFi 7 RBE973
Reply
RBR50 continues to drop wifi
Linsay000
Several times a day, my computer is able to connect with my Orbi, however it is no longer connected to the internet.   It isn't my modem because I'm able to use my internet on an ethernet cord from the modem
I have made sure my firmware is up to date and have unplugged my Orbi overnight.
It is several years old now, so I am wondering if that is the issue.  We have been considering purchasing the outdoor satellite, but don't want to spend the money if my whole system is going bad.
I'd appreciate any suggestion.  I typically can follow diretions but am not highly tech literate anymore!
thanks,
Linda
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Accepted Solutions
CrimpOn
Guru
Re: RBR50 continues to drop wifi
If you mark post "Solved", that will help othe users.
Message 5 of 5
All Replies
Guru
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router her by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 5
Guru
Any progress on this?
thanks,
Linda
Message 3 of 5
Linsay000
Yes, sorry I didn't reply I haven't been able to get onto my computer time-wise.  I called my cable company and had them bridge my modem and it is working great now.  It hasn't dropped since then.  Thank you for the suggestion!
Message 4 of 5
CrimpOn
Guru
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1401 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
