Reply
RBR50 current firmware?
gm2t2
My router version is 2.1.2.18  I am having trouble with it so thought newer version.  I see most people downgraded to 2.1.2.4.  Mine says "failed to get firmware version information"
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
Guru
Re: RBR50 current firmware?
v.18 was pullled from being auto updated.
Please try the beta:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/td-p/1533584/jump-to/first-unread-m...
Besure you do a factory reset on both router and Satellite after installing this FW update.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK853 (Router Mode) | and R9000 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, R9000, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 655 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
