- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
RBR50 devices not connecting to satellite
I’m the iPhone app when devices are not connecting to it I notice on the network map satellite 1 has a amber light next to it and not green.
Is anyone aware of a permenant solution for this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: RBR50 devices not connecting to satellite
Seems that satellite 1 has a bad wireless connection.
- In the Orbi iPhone app, when you see the yellow connection status do you see satellite 1 connected to the router or to satellite 2 (star or daisy chain topology)?
- Try to toggle Daisy Chain setting and see if that improves the connctivity.
- If possible, please get satellite 1 closer to the Router. Is satellite 1 closer to the router or is it closer to satellite 2?
My Setup | Internet Fiber ONT 250↓/250↑ | ISP Telenor | Wifi Router Orbi RBK50 AC3000, Router Mode, Wired Backhaul / Orbi RBK852 AX6000, Router Mode, Wireless Backhaul | Switches Netgear GS208 | Time Zone CET (Sweden)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Try resetting the satellite and then re-add it to the system? factory reset the satellite using the back push pin button. Hold it in until the top led turns on AMBER then let go. Wait for the WHITE led to slowly pulsate, Then hit the sync button on the back of the router then sync button on the satellite. You can do this while in the same room as the base router.
Swap locations with the workng satellite to see if it connects.
@Mj20181229 wrote:
I have a RBR50- one router and 2 satellites. Twice this week devices are not connecting to satellite 1 even though they are feet away from it. If I reboot satellite 1 devices will then connect to it. Firmware is up to date.
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
