- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 dropping some 5Ghz internet connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
So over the past 2 weeks certain 5ghz devices such as my smartphones, ring doorbell and devices hardwired to 1 RBK50 satellite (we have 2) have randomly been dropping their internet connection but maintaining their connection to wifi.
I have tried disabling beanforming, mu-mimo, 20/40 coexistence and experimented with every 5ghz channel. All of these worked fine for 2 years prior to the past 2 weeks. I already had wmm enabled and fast roaming disabled. All 2.4ghz devices are working fine.
I also experimented switching from my ISP's DNS to Google's DNS.
Does anyone have any clue as to what could be causing this and how to fix it? I will reset the router and everything will work fine for about 12-24 hours and then they start dropping again.
Thanks in advance for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 dropping some 5Ghz internet connections
Is the Orbi syste
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
ARRIS SURFboard SB6190 DOCSIS 3.0 Cable Modem and is working fine.
Home is 4500sqft and there is about 50ft between the router and satellites.
My nearest neighbor is 300ft from my house. I have experimented with all of those configurations you mentioned.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might bring in the RBS to say 40-45feet and see.
Try some of the suggestions. IF a reset hasn't been done, I would try this first off.
Also besure that Traffic Meter is disabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
or a cleaned up version from the horses mouth:
Hi Orbi Community,
Engineering was able to discover the cause of this issue and they are working on a fix in regards to the disconnections.
The issue comes from Traffic meter while daylight saving is enabled. The quick workaround is to disable the traffic meter.
To disable traffic meter:
Access orbilogin.com > go to ADVANCED Tab > Advanced Setup > Traffic Meter and uncheck Traffic Meter
We appreciate all your cooperation and patience working with us. We will provide update once we have the fix firmware.
Blanca
Community Team
