- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 firmware has never been updated
- Mark as New
- Bookmark
- Subscribe
- Permalink
I foolishly assumed that my Orbi would auto update firmware, but in the process of troubleshooting this morning realized that is SO not the case. My system is currently running firmware version 1.4.0.34.
Do I need to manually install all firmware versions released since, or can I jump to a more recent version? I apologize in advance for being so obtuse!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll need to update to v2.0.0.74 on the RBS first then RBR. Then you'll need to apply v2.2.1.212, Then you can go to more recent versions or check to see what the RBR finds for you.
@Ladnemk7 wrote:I foolishly assumed that my Orbi would auto update firmware, but in the process of troubleshooting this morning realized that is SO not the case. My system is currently running firmware version 1.4.0.34.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 firmware has never been updated
wow and I thought I was bad.
you may want to perfrom a factory reset and then see what firmware the orbi grabs from the server and go from there.
you can do manual updates, however I believe you can not jump to the front of the line. From where you're at you may have to install a cetain version and then do another to get you current.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:You'll need to update to v2.0.0.74 on the RBS first then RBR. Then you'll need to apply v2.2.1.212, Then you can go to more recent versions or check to see what the RBR finds for you.
how about tell me if this would have worked:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the info in responses. Sorry for the delay in my response.
I completed a factory reset, no new updates were found in the process. I then attempted a manual upload for the update noted 2.0.0.74(RBR50-V2.0.0.74.img) for RBS and received the following response: "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product. |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Final update.
I decided to push through and attempt the next recommended update (2.2.1.212) for both RBS & RBR. Worked like a charm. Then, the automated system kicked in and prompted for 3 additional group updates. I am very proud to announce that my wonderful little Orbi system is now operating as it should with the most recent available update. (2.7.2.104) Thank you all so much for your time and advice. I will NOT fall into this type situation again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working.
Be sure to save off a backup configuration to file for safe keeping. Saves time if a reset is needed.
Please mark your thread and solved so others will now.
Enjoy.
@Ladnemk7 wrote:Final update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just make sure you leave it alone
