- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 generating resolving hosts error
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 1 RBR50 and 3 RBS50 units.
Often (> 50%) I an receiving a 'resolving hosts' error on my computer. I find that I am connected to the nearest RBS50 with a stong signal. I then connect to the RBR50 using 192.168.1.1 with no problem. That would seem to elliminate the RBS50 as the issue.
The status shows that the internet connection is ok. If I reboot the router, the connection will be ok for a period of time then it will happen again.
Please help. Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 generating resolving hosts error
What FW version are you using?
Have you set up any reserved IP addresses ON the router for your PCs and devices?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The firmware level is V2.1.2.18
I have no reserved addresses. I know networking and this is baffling.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try the new v2.1.3.4. Do a factory reset on both router and Satellites then set up from scratch. Skip setting up the Satellites.
I would also do a IPCONFIG /release, then /renew then /flushdns on your PCs. Reboot reset of mobile devices AFTER you have set up the router.
Test. Then set up the Satellites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you find a solution? I am having the same problem (Resolving Host error...)
- Mark as New
- Bookmark
- Subscribe
- Permalink
What model Orbi system do you have?
