Reply
RBR50 got problem with satellite
arn0ld
 Hello, i have netgear orbi system at home with 1 router RBR50 and 2 Satellite RBS50. My house have 4 floor, i setup the router RBR50 at 1 floor, the 1 satellite at 2nd floor and the second satellite at 3rd floor.
The internet in 1st floor when all my device connect wifi direct to router is very fast as 260mb/s. The problem when i move to 2nd floor, the device connect to my first satellite at 2nd floor , the internet very slow although i stay next to the satellite as picture below.
Please help me resetup to make the satellite as fast as router.
Please help
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: RBR50 got problem with satellite
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
https://kb.netgear.com/31211/At-what-speed-and-bandwidth-can-my-Orbi-system-transmit-data
Daisy Chain, Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 57 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
