- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 intermittent DNS lookup issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 intermittent DNS lookup issues
Yet another reason to dump DST...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Success (at least for the last 20 hours)
I changed my NTP server to 1.pool.ntp.org
AND I turned OFF "Automatically adjust to daylight savings time"
Then rebooted. No problems since.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@SlimTrigger wrote:Success (at least for the last 20 hours)
Until the next firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reporting back after 36 hours after factory reset. Everything is working properly as others have also reported. I guess if all else fails, just do a factory reset and it should save you from more headaches. Good luck all.
I'm on latest firmware - V2.7.2.104
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know.
I'd make a backup configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy.
@mrkengos wrote:Reporting back after 36 hours after factory reset. Everything is working properly as others have also reported. I guess if all else fails, just do a factory reset and it should save you from more headaches. Good luck all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update... 48+ hours after factory reset all is working properly. Hope this DST/DNS bug will be resolved before fall.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@NoNo_BadDog wrote:Update... 48+ hours after factory reset all is working properly. Hope this DST/DNS bug will be resolved before fall.
nice
lets hope that's true.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@riegelj @kevindubs @NoNo_BadDog
Hello Orbi Community!
Thank you all for your contribution to this issue! Our NETGEAR engineers are looking for users that are still facing this issue to work with them directly to identy the root cause of the issue. If anyone is willing to work with our engineering team to debug this issue in real-time please send me a private message with your contact information and best time to reach you.
We are committed to getting to the bottom of this issue but need your help.
Thank you in advance!
ChristineT
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Better yet - tell your customers that its a support issue and requires payment to fix despite it being something you insterted via firmware update or other.. oh wait - you already are doing this!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Brentx wrote:Better yet - tell your customers that its a support issue and requires payment to fix despite it being something you insterted via firmware update or other.. oh wait - you already are doing this!
If you'll look around in this forum, several moderators have reached out offering to help. Perhaps you should do that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Steps to solve the ongoing DNS Lookup issues for all Negear Orbi modules as a result of a Netgear developer introducing a Cobal /Y2000 Daylight Savings Bug 3/14/2021:
1. Full Netgear Orbi Factory Reset
2. Uncheck Advanced>Administration>NTP Settings>Automatically adjust for daylight savings time
3. Update to firmware V2.6.2.104
BTW it took me 3 days with Spectrum Support, a Sectrum Truck rolled to check the cables, a new Sectrum Modem, all new cables - to finally determine it was a Netgear Orbi Daylight Savings Y2k bug!!!!!!!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks or letting us know.
@bdc2021 wrote:Steps to solve the ongoing DNS Lookup issues for all Orbin modules as a result of a Netgear developer introducing a Cobal /Y2000 Daylight Savings Bug 3/14/2021:
3, Update to firmware V2.6.2.104
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you want your equipment to work and troubleshoot thru the problems then a reset is a valid troubleshooting step. Has been for a long time. Others are posting that is working for them to fix this issue. So try it out.
Also saves time if you have a good working backup configuration that helps to apply after doing a reset. Good users have this one hand.
Or reach out to NG support
If your not satified with your product, find something else.
Good Luck.
@archp wrote:
Resetting stuff isn't a solution or downgrading firmware. This is about customer experience. I have 4 satellites and work from home. Also have custom ssids for 2.4ghz, the solution shouldn't be to make customers unscrew the company's screw ups. Literally all of these solutions put the onus on the user. If support was free they would have been notified much sooner as many more people would gave called in and complained. The mere fact that every support call prompts the user to spend more is why they have no clue what's going on. Its like saying everytime your engine stops working in your car, swap out the engine, well I don't have a formula one team at my disposal. Moderators aren't netgear employees either. Just a terrible service and support options for such expensive network gear. This is your halo product and your solutions are reset and spend hours getting back to status quo, how about doing your jobs and fixing it on your end.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ill post as I see fit. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Alternative suggestions:
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is not happening to all. It is now 4 days after the time change and I never lost DNS.
I. have "Automatically adjust for daylight savings time" unchecked and the Orbi time is 1 hr behind.
Does that mattar? All my devices are working correctly, my Win10 PC checks time on its own. DNS is working (I use 1.1.1.1, 8.8.8.8, 208.67.222.222). I think I'll leave everything as is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did factory reset yesterday afternoon, around 1:30pm.
Firmware 2.7.2.104
I changed NTP to time.nist.gov
Automatically adjust for DST is checked
DSN 8.8.8.8/8.8.4.4
So far, so good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@kevindubs wrote:I did factory reset yesterday afternoon, around 1:30pm.
Firmware 2.7.2.104
DSN 8.8.8.8/8.8.4.4
So far, so good.
Nice
Lets hope it all works out for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does it matter that my Orbi is 1 hr behind?
It is not set to adjust for DST automatically and did not. It has been working fine.
