- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 internet speed lower on lan ports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a router and sat. 2100 sqft home. I did a speed test inside the Orbi iphone app and Orbi shows the full internet speed.
However, when doing a internet speed from a pc connected to a lan port on the Orbi router, there is a loss of about 100mb.
I have tried resetting the Orbi router, connected pc to different lan ports on the Orbi router, and using a different cord.
I would think it would not be that much of processing from the Orbi router wan port to one of the lan ports.
I have updated the firmware, the issue was there before updating the firmware.
Not sure what is next, or is it expected to loose this much due to how Netgear has decided to do switch on this product.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 internet speed lower on lan ports.
Be sure your PCs networking adapter supports 1000Mbps connection rates. If thats conneting at 100Mpbs, then this will be a cause.
Be sure to use a good quality LAN cable between the PC and RBR. CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. The cable is cat6. I went into the statistics page in advance. It shows I am connected at 1gb.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@speakercpu wrote:Thanks for the reply. The cable is cat6. I went into the statistics page in advance. It shows I am connected at 1gb.
OK, what you're seeing is unexpected so we must investigate other possibilities.
- How are you measuring the speed on your PC? Is it via a website or app like speedtest.net? That is preferrable than reading the speed from the Orbi admin website or app.
- Can you connect your PC directly to your ISP modem and measure the speed the same way? That is another way to isolate whether it is your PC or the Orbi.
- Do your wireless devices connected to your Orbi show the same speed drop on the speedtest.net website or phone app? This tells us whether it is a wired-only issue or an Orbi-wide issue.
- Is your ISP modem also a router device, e.g., Comcast internet gateway? If it is also a router, is it in bridge mode to your Orbi or do you have two routers operating (Double NAT)? If Double NAT then there is some inefficiency and we can help resolbe that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was measuring speed using bing internet speed test.
I switch to the website/then app for speedtest.net. Connected straight to the modem sent by spectrum i get 230.
I had contract tech look at it a few mins ago. He said that spectrum would need to send one of their ppl out to look at it.
Then I hooked the Orbi back up, and check on wifi using the speedtest.net app. it was 225 download.
When I power off the modem and the Orbi router..then power the modem back on(and wait for it to be online), turn the Orbi router on and wait for it to give my pc(on lan port) an ip, I used the app for speedtest.net and got 325mb.
- Mark as New
- Bookmark
- Subscribe
- Permalink
=== I am not sure about this, have not found a way to see.
- Mark as New
- Bookmark
- Subscribe
- Permalink
also just saw this post.. https://community.netgear.com/t5/Orbi/Cable-service-at-200mps-but-LANs-out-of-Orbi-WiFi-6-router-max...
it seems similar to my issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think I am going to close this out. I am tested the speed using the speedtest app on windows machine, connected to the Orbi router on the lan port, and I get almost all of the paid bandwith minus about 25mb...
Seems like the something must be happening during the day on my network to slow it down some...I will need to look into that.
thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Daytime speeds may vary depending on whats going on on your network side of things and also whats going on with the WAN side of things. Rememer, theres alot more people working from home now days so the ISPs are trying to maintain speeds and bandwidth for everyone. You may see speed drop during working hours. Going to be like this for a while.
Good Luck.
