Reply
RBR50 loosing WIFI - Wired seems to work
RHRathje
I have an RBR50, and it suddently drops WIFI every 5-7-10 minuts. When it drops wifi, I still have wired connection to the internet trough my RBR50, but all units connected via WIFI looses connection to router and Sat. I have triede latest firmware aswell as rolled back to 2.3.1.48 but it's the same.
After loosing connection, units reconnect after few seconds to at minut or so. It has been like this for a week but before this, it has been working perfectly for the last year.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: RBR50 loosing WIFI - Wired seems to work
Update the system again and after the FW is updated, do a factory reset and this time, don't enable Armor at all. Leave it off. Setup the RBR as suggested.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 4 of 6
All Replies
Guru
Try a manual load of the v60 FW files, factory reset and setup from scratch.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 6
RHRathje
Thank you for your reply.
Idon't know about the modem.
There are approx 30ft between my router and sat. and our flat is 140 square meters (approx 1500 square feet). We don't have many neighbours with WiFi.
I have tried everything you recommend, but It doesnt change anything. I have tried to enable Armor, and for some reason it seems to help. It doesnt eliminate the issue, but I don't loose WiFi just as often after.
Message 3 of 6
Guru
Message 4 of 6
RHRathje
Had to make a couple of resets, but now it works. Thank you very much.
Message 5 of 6
Guru
Is Armor enabled now or did you not enable it this time?
Glad its working now.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 858 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
