Orbi WiFi 7 RBE973
Reply
RBR50 probleme mise a jour
2558-mata
bonjour
suite a une mise a jour manuel de mon RBR50  je n'ai plus de connexion internet
la base clignote blanc et le bouton on/of passe de vert a l'allumage puis clignote quelques instants rouge pour repasser vert
j'ai upgradé de la version 1.4.0.18 a la version suivante1.4.0.34 avec succes donc vue le nombre de versions j'ai mise a jour lune version intermediaire 1.9.1.12 .
fallait-il upgrader sans sauter de versions?
avez vous une solution ?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 8
Accepted Solutions
2558-mata
Re: RBR50 probleme mise a jour
Hello
my update problem is solved
my firmware installed on the RBR50 was corrupt
I found on the forum the procedure to reinstall the original firmware.
"https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client."
it works without problem.
thank you FURRYe38 for your support.
Message 7 of 8
All Replies
Guru
en anglais s'il vous plaît
Message 2 of 8
2558-mata
RBR50 update problem
Hello
following a manual update of my RBR50 I no longer have an internet connection
the base flashes white and the on / of button changes from green to ignition then flashes red for a few moments to return to green
I upgraded from version 1.4.0.18 to the following version 1.4.0.34 with success, therefore considering the number of versions I updated an intermediate version 1.9.1.12.
was it necessary to upgrade without skipping versions?
Do you have a solution ?
Message 3 of 8
Guru
What model Orbi do you have? Is this in regards to the RBR50? Or something else?
Try a power OFF of the ISP modem and RBR for 30 seconds, then back ON with the ISP modem first, then RBR to see if it re-connects. Can try a factory reset on the RBR as well.
Message 4 of 8
2558-mata
Hello
the problem concerns the RBR50 router.
I can no longer access the settings.
there is no more wifi and no connection with the eternet cable despite a factory reset on the RBR and turning off and on the modem and RBR.
Message 5 of 8
Guru
Please make contact with NG support about this.
@2558-mata wrote:
Hello
Message 6 of 8
2558-mata
Hello
Message 7 of 8
Guru
Glad you were able to recover it and get it working.
Enjoy. Smiley Wink
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1728 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
