- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 - rebooting daily after internet via wifi drops
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since the latest firmware update (2.7.2.104) I've been rebooting daily. Phone connects w/o internet, some devices connect, some have no connection. I've had the Orbi for almost 5 years, and can't remember having this many issues. I bought Orbi as a housewarming gift for my daughter, and now am wondering if I should have...
Have done factory reset and complete reinstall, and changed NTP setting. Lasted for about 24 hours before phone lost internet via wifi and I had to reboot. Strangely, wifi connection is strong but with no internet. Wired internet connection remains. Not impressed, but happy for any assistance.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
This appears related to the recent DNS/NTP issue. The router appears to lose the ability to relay DNS requests on any FW version.
To confirm, try to set the DNS on your laptop or phone to something other than the router. No need to roll back.
Here's a link to one of many other threads on this topic:
@lordga wrote:
You can't rollback they firmware. That was the first thing I thought of. Tried the manual process, it doesn't work.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 - rebooting daily after internet via wifi drops
I thought my router was dying after having it for 3 years! But it's not just you, I'm reading 100s of other posts and it appears to be a combination of the 2.7.2.104 firmware update and DST happening. All of a sudden your WAN connection dies and kills all of your Wi-Fi connections too. Seems like things that are hardwired appear to be fine. So from other posts I've done all of what you did and disabled NTP and Traffic Monitoring. I completed it at 3/20@20:00 and everything still appears to be stable at the time of this post. I'm trying to see if I'll make it 24hrs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since the latest firmware update (2.7.2.104)....seems to be a common theme
roll your firmware back
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sure you can IF you can find the right (stable) firmware. Many have done it. Do a search.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:This appears related to the recent DNS/NTP issue. The router appears to lose the ability to relay DNS requests on any FW version.
This appears related to the recent DNS/NTP issue which is linked to FIRMWARE
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue here, was driving me nuts with reboots to modem and router. Didn't seem to happen right after firmware update so didn't really seem to trigger that as being the culprit. I did the DST suggestions, hope that takes. With kid and wife working from home and having interviews coming up reliabe Internet would be nice. Since making these changes are you still good?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@AlaskaDave wrote:Same issue here, was driving me nuts with reboots to modem and router. Didn't seem to happen right after firmware update so didn't really seem to trigger that as being the culprit. I did the DST suggestions, hope that takes. With kid and wife working from home and having interviews coming up reliabe Internet would be nice. Since making these changes are you still good?
From what I read and what I tested on my RBK50 (1 RBR, 1x RBS wired, 2x RBS via wifi on FW 2.7.2.104), there is only one modification in the settings required (login via web GUI):
-> disable "Traffic Meter" in the advanced tab
-> if this does not help, you can also deactivate DST and use an alternative time server (I guess this is not reuqired)
facts:
- the DNS/disconnect issues are caused by a bug (which is present also in older firmwares)
- the issue usually starts at daylight saving (or a few hours later -> when "DHCP lease" renews the device IP)
- the best/easiest fix is to DEACTIVATE "Traffic-Meter"
Here are a few offical statements from Netgear:
https://community.netgear.com/t5/Orbi/Orb-RB40-MAJOR-DNS-Issue/m-p/2074390/highlight/true#M117523
https://community.netgear.com/t5/Orbi/DNS-problems/m-p/2074345/highlight/true#M117514
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still looking for for the DNS 'bug' in my old beat up firmware. It ain't there
- Mark as New
- Bookmark
- Subscribe
- Permalink
@vajim wrote:Still looking for for the DNS 'bug' in my old beat up firmware. It ain't there
To clarify:
The issue occurs ONLY when "Traffic-Meter" in ENABLED. If "Traffic-Meter" ist DISABLED, you are fine (also on FW 2.7.2.104).
I tested it last weekend:
- I took a actual save of my config
- then I activated "Traffic-Meter"
- waited around 24h
- on the next day, my network was broken suddenly for many attached devices
- then I done a factory reset of my RBK (incl. the satellites)
- afterward setup from scratch and reloaded the previously saved config (with "Traffic-Meter" disabled)
- and all is fine since then
So, do NOT reply if you are NOT interested in "Traffic-Meter" ! We try to explain the users how to (temporary) fix this issue which also affects older FW (again, with "Traffic-Meter" enabled).
As stated above and several times in this thread, the issue IS CAUSED by a bug with "Traffic-Meter" and daylight saving.
And for the ones they really search for help:
DISABLE "Traffic-Meter" on your system, this helps on the current FW and also on older ones.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@vajim wrote:To clarify...I don't have the problem
now please go away and try to help others
You NOOB, I try that, but you are spamming all threads here in the forum with NOT HELPFUL comments.
NOOOOOOOOOOOOOB
- Mark as New
- Bookmark
- Subscribe
- Permalink
NOOOOOOOOOOOOOB
You are certainly confused my friend. In a forum such as this ALL people can make posts as they see fit. Just ask @FURRYe38
IF you don't like my posts, ignore or scroll on. You are NOT the forum police.
It sounds and looks like you can't accept an opposing view. You slamming me provides NO help to others here while exposing your child like behavior.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The user @vajim has NOT enabled "Traffic-Meter", and he has not tested is on his old firmware.
To the users who still search for help with wifi drops and enabled "Traffic-Meter" -> DISBALE it and you should be fine.
To clarify:
- waited around 24h
- on the next day, my network was broken suddenly for many attached devices- then I done a factory reset of my RBK (incl. the satellites)
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Ha_Ku_Na wrote:The user @vajim has NOT enabled "Traffic-Meter", and he has not tested is on his old firmware.
Give it up.....nobody cares what you post.
I did test TM and nothing happened so go back to sleep.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Describe your test procedure as I did.
And how long have you tested it ? 5 minutes
- Mark as New
- Bookmark
- Subscribe
- Permalink
No....you wouldn't believe me anyway. Go talk to someone who cares.....shoo....shoo
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see, you have problems with reading posts which are longer than 10 words.
You have no practical experience with real debugging, sensory problems (with other views than yours) and many other handicaps.
Because: you are the one who does not accept other suggestions ... probably someone can help you in the near future ... if not I don't care
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Ha_Ku_Na wrote:I see, you have problems with reading posts which are longer than 10 words.
Because: you are the one who does not accept other suggestions ... I hope someone helps you in the near future ... if not I don't care
Are you done.....feel better now?
We can stop this volley ball game and become friends or keep this up for as long as you wish.
- Mark as New
- Bookmark
- Subscribe
- Permalink
you a friend, not even a good joke, why not you do stop this..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
For the ones who are interested in a possible solution (because a troll an myself have spammed this thred).
possible solution:
- waited around 24h
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
vajim, You not the forum police nor you anywhere near qualified to be, let alone be posting in the forums or givein out information. Everytime someone posts helpful information you dump and spew pointless duplicated false ane invalid infomation. You badger and troll anyone trying to be helpful to others that are looking for help. Don't let anyone talk about there eperiences in a good way but for you is ok to. Your a complete waste of time and air to anyone in this forum. You must have a sad life to come here an dump on anyone giving help. The communiity is not yours to dump in. Go somewhere else. Stop playing the victim when your completely the instegator. You bring this all to your self.
NetGear, Please ban this user one and for all!!! Stop this once and for all for community sake!
@vajim wrote:Give it up.....nobody cares what you post.
