- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 rebooting hourly
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR50 w/ 1 RBS50 Satellite ~ 30 feet (synchs blue)
Firmware 2.3.1.44
Spectrum w/ Arris TM1602 modem
WPA2-PRK [AES]
House 2,700 sq ft
Edge of Neighbor's house ~110 feet can see their wifi very low signal
Router is resetting frequently. Today has been every hour..
2.4 is set to channel 11.
Beamforming is on.
MIMO is on
Daisy-Chain is on
When router goes into factory reset/update mode if I plug internet directly into computer internet is available, so doesnt seem like the cable is the issue.
Reset it to factor default yesterday
Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 rebooting hourly
How do you see that the Router is rebooting? Do you see in the Logs (in the web GUI under >> ADVANCED >> Administration >> Logs) that the router is initialized?
- Mark as New
- Bookmark
- Subscribe
- Permalink
A few of the times I've been sitting there when it starts pulsating white.
Yes, log looks like this, rarely see entries spanning longer than an hour.
[DoS Attack: ACK Scan] from source: 17.33.9.65, port 443, Sunday, March 24, 2019 16:38:00
[admin login] from source 192.168.1.9, Sunday, March 24, 2019 16:37:55
[DHCP IP: 192.168.1.7] to MAC address f0:98:9d:4b:df:85, Sunday, March 24, 2019 16:37:42
[DHCP IP: 192.168.1.9] to MAC address f8:2f:a8:da:2c:bb, Sunday, March 24, 2019 16:37:25
[DHCP IP: 192.168.1.5] to MAC address 7c:1c:4e:57:96:ea, Sunday, March 24, 2019 16:36:25
[DHCP IP: 192.168.1.4] to MAC address 08:02:8e:90:9b:c0, Sunday, March 24, 2019 16:36:15
[DHCP IP: 192.168.1.3] to MAC address 68:9a:87:bb:75:b6, Sunday, March 24, 2019 16:35:55
[DHCP IP: 192.168.1.2] to MAC address 68:9a:87:c4:a4:97, Sunday, March 24, 2019 16:35:53
[Time synchronized with NTP server] Sunday, March 24, 2019 16:35:35
[Initialized, firmware version: V2.3.1.44] Sunday, March 24, 2019 16:35:19
- Mark as New
- Bookmark
- Subscribe
- Permalink
and again and this time it lost it's time zone. It's should be 17:51
[DHCP IP: 192.168.1.7] to MAC address f0:98:9d:4b:df:85, Sunday, March 24, 2019 16:52:45
[admin login] from source 192.168.1.9, Sunday, March 24, 2019 16:52:44
[admin login failure] from source 192.168.1.9, Sunday, March 24, 2019 16:52:41
[DHCP IP: 192.168.1.9] to MAC address f8:2f:a8:da:2c:bb, Sunday, March 24, 2019 16:52:22
[DHCP IP: 192.168.1.5] to MAC address 08:02:8e:90:9b:c0, Sunday, March 24, 2019 16:52:07
[DHCP IP: 192.168.1.9] to MAC address f8:2f:a8:da:2c:bb, Sunday, March 24, 2019 16:52:02
[DHCP IP: 192.168.1.4] to MAC address 7c:1c:4e:57:96:ea, Sunday, March 24, 2019 16:51:54
[DHCP IP: 192.168.1.6] to MAC address f8:95:ea:12:48:48, Sunday, March 24, 2019 16:51:52
[DHCP IP: 192.168.1.10] to MAC address 48:bf:6b:3f:b4:77, Sunday, March 24, 2019 16:51:50
[DHCP IP: 192.168.1.6] to MAC address f8:95:ea:12:48:48, Sunday, March 24, 2019 16:51:50
[DHCP IP: 192.168.1.3] to MAC address 68:9a:87:bb:75:b6, Sunday, March 24, 2019 16:51:47
[DHCP IP: 192.168.1.2] to MAC address 68:9a:87:c4:a4:97, Sunday, March 24, 2019 16:51:47
[Time synchronized with NTP server] Sunday, March 24, 2019 16:51:26
[Initialized, firmware version: V2.3.1.44] Sunday, March 24, 2019 16:51:11
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems to me in this case, a factory reset would be the first steps I would take. You have the current firmware version according to your post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've reset it a couple of times and it seems to have reset itself once as well...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I like using the paperclip method after a cold start on each unit in the RBK5x and let the hardware do its thing. Base unit first of course. After everything's up, you can go into the web gui and make requisite settings changes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since you only have 1 satellite, I would disable Daisy Chain.
Did you reset both base and satellite and setup from scratch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router reboot can be caused by IP loops, what wired devices do you have attached to Orbi please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just turned off Daisy Chain.
I don't think I've done the factory reset on the Satellite at least not in the last few days. Will give that a try.
Normally I have a Windows 10 PC connected via hardware, but I've eliminated that over the last 23 hours or so.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did a factory reset on the satellite about 10 hours ago. Went down at least once while asleep, but the log indicates it's been up a little over 5 hours at this point so that feels like progress.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you using Auto or manual channels?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2.4 is set to 6
5.0 is set to 48
Got home, power is on but router not broadcasting SSID. Satellite Magenta.
Cycled the power on the router and its now back.
Something odd I noticed this morning. In the Admin console the router had assigned 192.168.1.2 to two different devices, one on 5.0 and the other on 2.4. Any clues?
The only device that has a hard IP is a wireless printer that's on .191.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would make contact with NG support. Posible bad system. Ask about an RMA.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! I started that process, I need to send them a copy of my receipt... searching
Thanks for all the suggestions!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds good. Let us now how it turns out. Hopefully NG can fix this.
