Orbi WiFi 7 RBE973
Reply
RBR50 slow wired speeds
badler4
I check the speed test on the Orbi app, and I'm getting 600-750Mbps (paying for 912Mbps from Spectrum).  I have a wired connection, Cat 8, from my ethernet port on the Orbi router to my laptop docking station.  Run a speed test, and I'm getting no better than 225Mbps.  What am I missing?  Did a factoy reset on the Orbi, no changes.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 14
Guru
Re: RBR50 slow wired speeds
Can you connect your laptop directly to the RBR and by pass the dock station?
Do you have a different wired PC to test with and compare results?
Use Ooklas installable speed test app for Windows...
Message 2 of 14
vajim
Master
do not use the app
try another web base spped test site
Message 3 of 14
badler4
speedtest.net still giving my 250Mbps approx.  Wired it directly to my laptop (no dock), no improvement.  ISP is Spectrum, and modem model #is E31T2V1 (Charter).
Message 4 of 14
badler4
firmware is V2.5.2.4 on the Orbi
Message 5 of 14
vajim
Master
can you try it without the docking station?
Message 6 of 14
badler4
directly connected now from orbi ethernet port to laptop.
Message 7 of 14
Guru
Is Armor, Circle or Traffic Meter enabed on the RBR?
Message 8 of 14
badler4
Yes, the traffic meter is enabled. I have had to step away from home for the moment, but I can try and disable it later if you think this might be something that is rattling down the speed.
Message 9 of 14
Guru
There was posts a while back that mentioned Traffic meter causing speeds not to be where they are at. Try disabling it, if no change, I would factory reset and setup from scratch and be sure not to enable the aforementioned features. Wired speed should be to spec then.
Message 10 of 14
DeeLo
Sorry I’m new to this.
I’m having a similar problem. Did you ever get this resolved?
Message 11 of 14
Guru
How are you speed testing?
What devices are you using to speed test with?
Browser speed testing or app speed testing?
Message 12 of 14
badler4
For me, I think it came down to my hardware.  Laptop was a bit older, so ethernet port was not able to support the higher bandwidth.  That said, I've moved on from this router and have a new laptop.
Message 13 of 14
Guru
Good Luck.
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 1591 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
