Orbi WiFi 7 RBE973
Reply
RBR50 synched with Satellite but cannot find
Meibc222
Follower
Firmware 2.1.4.10
Even though the Satellite lights is blue indicating 'synch' my router cannot find the satellite. On the mobile app it acknowledges the router but cannot find the satellite. I have done a cold reboot; power cycle down; etc.. no luck..i have 'synched' a couple fo times and each time i get a solid blue light. But when i try to add satellite on the application it cannot find.
anyone have any thoughts how to resolve?
thanks
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only), RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 3
Retired_Member
Not applicable
Re: RBR50 synched with Satellite but cannot find
relax.....give it a while.  I've heard the app is not that good.  Blue light should go out indicating all is well.
Message 2 of 3
DarrenM
Sr. NETGEAR Moderator
Have you gone to www.orbilogin.net in a web browser and see if the satellite shows up?
DarrenM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 477 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
