- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 + two RBS50 -- No route between devices on LAN
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have this issue intemittently.
I have an RBR50 with two RBS50 satellites. Devices connected to satellite #1 cannot connect -- no route, host unreachable -- to devices connected directly to the router or to the other satellite (#2). The WAN is accessible, however. Rebooting the offending satellite (sometimes) cures the problem. I would like a more persistent solution.
Suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 + two RBS50 -- No route between devices on LAN
Try updating FW to v16 if this hasn't been tried.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@txl wrote:Devices connected to satellite #1 cannot connect -- no route, host unreachable -- to devices connected directly to the router or to the other satellite (#2). The WAN is accessible, however.
Could you please describe the connection process. i.e. trying to "ping" one device from another? open a web site on a device? stream a camera? connect to a file server?
Do these devices have IP addresses "assigned" to them in the system?
Orbi is running as a "router" or an "access point"?
