Orbi WiFi 7 RBE973
Reply
RBR50 vs RBK50
Lobby125
Initiate
RBR50 vs RBK50
Purchased RBK50 router and sattelite, but received RBR50 router and satellite. Can anyone advise on the difference?
Thank you!
Message 1 of 3
Accepted Solutions
Lobby125
Initiate
Re: RBR50 vs RBK50
Just found a post from St_Shaw. Is this an accurate response?
"I don't understand your question...  The RBK50 is a kit that contains one RBR50 router and one RBS50 satellite.
The RBK50 is a kit, not a router.
If you have the RBR50, that implies you have only the router.
If you have only the router, then you have no satellites."
Message 2 of 3
All Replies
Lobby125
Initiate
Re: RBR50 vs RBK50
Message 2 of 3
Guru
Re: RBR50 vs RBK50
RBR50 is a model of the Orbi Router base unit. The RBK50 is a Orbi system kit box set that includes the RBR50 base router and a RBS50 remote satellite. These are all in the box when you buy it. I believe the RBK50 in box set is just 1 router and 1 satellite. The RBK53 is a base router and 2 satellites. https://www.netgear.com/support/product/orbi.aspx
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 18533 views
  • 5 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
