- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 w2 satellites dropping wifi every night
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have one RBR50 and two RBS50 satellites all running V2.5.1.8. Internet has been very stable. Each night over the last 5 nights, My devices are not able to reach the internet. When I log into my orbi system, it says the internet connection is good. I can't seem it isolate the issue. I reboot the system in the morning and it then works fine for the day unitl I wake up and find the same issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 w2 satellites dropping wifi every night
@danfCO wrote:I have one RBR50 and two RBS50 satellites all running V2.5.1.8. Internet has been very stable. Each night over the last 5 nights, My devices are not able to reach the internet. When I log into my orbi system, it says the internet connection is good. I can't seem it isolate the issue. I reboot the system in the morning and it then works fine for the day unitl I wake up and find the same issue.
Get rid of V2.5.1.8.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
- Mark as New
- Bookmark
- Subscribe
- Permalink
no copy paste will fix bad FW
