Reply
Highlighted
RBR50 wil not allow me to to add printer
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 8
Highlighted
Master
Re: RBR50 wil not allow me to to add printer
Are you trying to add a ReadySHARE USB printer or a wireless printer? Please describe the issue you're seeing so we can help you Smiley Happy
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBK50 AC3000, Router Mode, Wired Backhaul / Orbi RBK852 AX6000, Router Mode, Wireless Backhaul | Switches Netgear GS208Time Zone CET (Sweden)
Message 2 of 8
Highlighted
Guru
What is the Mfr and model# of the printer?
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 3 of 8
Highlighted
HP color laser jet pro M54dw
Message 4 of 8
Highlighted
I am trying to hook up a wireless printer.  The message keeps saying that there is no wireless internet to hook to.  But I know that is not the case as I am sending these questions out to netgear.
Message 5 of 8
Highlighted
Master
Have you tried to add the printer using WPS?
I have the M451dw and it was straight forward to attach the printer to Orbi using WPS.
Message 6 of 8
Highlighted
Guru
Ensure the printers FW is up to date as well.
Is that a 54dw or 254dw model?
What security mode are you using on the Orbi? Auto or WPA or WPA2?
Message 7 of 8
Highlighted
Issues with wifi printers are often nothing to do with the wifi source, your Orbi, which just sits there delivering wifi. It is up to your printer to play ball.
Setup is down to the way in which you configure the printer. Most wifi printers use an program on your PC to set them up. It is probably somewhere on your PC. You just need to find it and run the thing.
I suspect that running the printer utility will deal with the prompt you see.
That is how I fixed a neighbour's HP printer recently.
Connecting your HP wireless printer | Wireless Printing Center | HP® United Kingdom
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1008 views
  • 1 kudo
  • 4 in conversation
Announcements
