- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 with a fucsia dot on the network map
- Mark as New
- Bookmark
- Subscribe
- Permalink
my router on the network map appears with a fucsia dot, whilst the satellite with a green one and on the main scree of my app next to the image of the router with the moving disc it says Internet: offline, everything seems connecting and operating fine
Any idea why is that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 with a fucsia dot on the network map
what modem/gateway are you connected to?
A combo device can cause a double nat and give you that.
https://kb.netgear.com/30186/What-is-Double-NAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does it report the same thing at orbilogin.com? Lately the app has been reporting wrong information with regard to router, satellites and devices. Not sure why, unless the latest app update has a bug.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will try to answer your questions I hope im getting the answers right
gateway 212.158.250.32
after i can read default gateway 192168.1.1
I cant find anything for modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
the orbi is plugged into something providing internet. Whether it be a modem, ont, gateway.
What device (and model) is it plugged into?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wi-Fi Hub (Vox 3.0/THG3000G) vodafone is my provider
- Mark as New
- Bookmark
- Subscribe
- Permalink
i cant login into orbilogin.com, is not accepting my password
- Mark as New
- Bookmark
- Subscribe
- Permalink
Go to orbilogin.com > Advanced > Setup > Internet setup and screenshoot that page and post it.
Or copy anbd paste the settings here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A couple things.
Your gateway is a combo device. Meaning your in a double nat. That can cause what you're seeing on the app. You'd either want to put the gateway in modem only/pass through mode, the orbi in access point mode (probably easiest route), or the orbi's IP address in the gateways dmz.
to put the orbi in ap mode, you'd need to log in via the browser. Which you don't know the password for. there is a password recovery option. https://kb.netgear.com/31016/How-do-I-recover-my-Orbi-admin-password
if you didn't set that up or don't know the answers to the questions, then your only option to get back in would be to factory reset the orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok here are the screenshots
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ksagarzazu wrote:ok here are the screenshots
Unfortunately the screen shot shows me nothing, all fields are blank.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@ksagarzazu wrote:Wi-Fi Hub (Vox 3.0/THG3000G) vodafone is my provider
