- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 with firmware 2.5.2.4 - Frequently drops internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have been using this router for couple of years with no issue. Recently started facing frequent drops in internet connectiivty. Saw in chats messages, upgraded formware to latest, still facing the same issue.
Just clicking on apply on routers internet setup web page is automatically fixing (because no issue with modem connection)
Model: RBR50
Firmware: 2.5.2.4
Parental Control - Circle enabled
Any one facing similar with latest firmware 2.5.2.4
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Frequently drops internet connection
Factory reset the RBR and setup from scratch, this time, do not enable Circle. Leave it disabled. See if problem continues.
Was a long thread last year about Circle causing problems.
Also, there is nore recent versions of FW:
If your in the US Region:
However this version of FW does not support Circle!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Motorola Surfboard SB6141
I see NG listed a new fw for RBR50 (Orbi Router) Firmware Version 2.7.1.60 (for US Region Only)
First I'll try with this, if no good, will disable Circle and try
Thanks for the response.
