Orbi WiFi 7 RBE973
Reply
RBR50 won’t connect to Apple servers
Pdn
Hi. OrBi RBR50 with 2 sats will not allow connection to Apple servers. So Apple TV works for Netflix and Prime but not Apple Movies, Trailers or software updates and cannot download new apps. Apple iPad cannot upgrade software or download apps but works fine to browse the Internet. iMac similarly cannot upgrade software or log in to Apple accounts but is totally fine for running other software, internet browsing etc. speeds running 230Mbps up and down. This is a very specific problem of Orbi and Apple servers and no other interaction I can find. My only solution at present is a backup old Wi-Fi router with lower speeds. Any idea what to do?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Guru
Re: RBR50 won’t connect to Apple servers
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 4
Guru
Any progress on this?
Message 3 of 4
Pdn
No. In fact it got worse. The Netgear Orbi router is blocking traffic to most major websites now. It expanded from Apple to no including Amazon and Google. Hours spent resetting to factory settings and restarting everything failed to resolve. I’m returning this junk to Costco today.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 778 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
