- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR50
GM I would like to know if the satellite stays blue when connected properly with the router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50
If you are asking about the working of your Orbi device, try posting in the section of this community for Orbi systems.
There is also support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re:
Good Morning, I just brought the orbi RBR50 the router on the main floor put the satellite up stair, my question is with satellite upstairs we still kick off the game my son is playing on his iPad
or slows down I was wondering if I have set up right, is the blue light on the satellite supposed stay blue
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Re:
The ring at the top of the satellite turns blue for three minutes once it is correctly connect to the router. Then it turns off. Here is that section of the manual:
What it your satellite doing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50
Seems that there is some ambiguity.
The manual says:
For the Add-on satellite ring LED:
- Blue for three minutes. The connection between the satellite and the router is good.
But then it says:
- Off. The satellite synced to the router and is working normally.
What does Solid Blue mean?
My experience (three different satellites) is that when the Orbi satellite is connected and behaving as expected the ring light is off. The Blue phase is transitory, during setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50
From my experiences, when I see BLUE on solid, it's synced and connected to the base router during the setup of the base or satellite. OFF just means that everything is working correctly during normal operation. I believe some of the working of the support site could be updated to be a bit less ambiguous though.
The manual says:
But then it says:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50
Solid continuous blue is not a normal condition and means that something unusual is going on.
Probably time to conduct a factory reset and/or update the firmware in the Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50
Solid BLUE means the system got connected. Once the BLUE turns OFF after the period of time, then the system is working normally.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
