Orbi WiFi 7 RBE973
Reply
RBR50
FrancisTea
Follower
RBR50
Hi, If the router label missing(Name & Password) , how can I connect the router to do the config from my mobile (after factory reset)
Model: AC2100|Nighthawk AC2100 Smart WiFi Router
Message 1 of 3
Guru
Re: RBR50
Need a wired PC or laptop and web browser connected to the back of the RBR.
Message 2 of 3
CrimpOn
Guru
Re: RBR50
@FURRYe38 is correct. When Orbi is 'factory reset', the wired interface comes up with user name "admin" and password "password".  The WiFi comes up with the SSID and password printed on the label, which is missing.  The only solution is (a) to get a friend to bring over a laptop with an ethernet port, or (b) carry the Orbi someplace where there is a desktop or laptop that can connect to it.  Configure the Orbi.  Verify that the mobile can connect to it, and take it home again.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 595 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
