Orbi WiFi 7 RBE973
Reply
RBR50
RLWTR
Tutor
RBR50
Can I connect my modem to my router and then the router to the network switch for back haul to all of my cat5 outlets? Modem and Router would be on different floors from network switch? Is so what switch would you recommend.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Accepted Solutions
Guru
Re: RBR50
yes, its actually recommended to go Modem----->Router----->switch.
If you try to go modem----switch-----router, you'll have issues and it won't work with a standard modem.
Recommending a switch would need more details. What are you goals with it? Ports needed? Vlan? etc.  more details help.
If its just standard home use, most unmanaged switches work great.
Message 2 of 5
All Replies
Guru
Re: RBR50
Message 2 of 5
RLWTR
Tutor
Re: RBR50
Thanks!!! Standard Home for now just 2 satellites and 3 TVs.
Message 3 of 5
Guru
Re: RBR50
I'd look at an unmanaged switch. They're pretty much set and forget and just work. When you start getting into managed switches, there's more setup/configuration.
You can usually find an 8 port unmanaged switch for around $20 if you watch.
Message 4 of 5
RLWTR
Tutor
Re: RBR50
Thanks so much for the info!!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1056 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
