Orbi WiFi 7 RBE973
Reply
RBR50
Toeknee72
RBR50
Will the RBS40V-200 speaker/WiFi extender work with my Orbi router RBR50?
Message 1 of 6
Accepted Solutions
CrimpOn
Guru
Re: RBR50
Yes.  Check the product data sheet:
https://www.netgear.com/images/datasheet/orbi/RBS40V-200.pdf
"Works with ANY router, but is optimized for the Orbi system."
Notice there are two different firmware loads:
  • Extender mode
  • Orbi mode
https://www.netgear.com/support/product/rbs40v-200.aspx#download
p.s. Mine is arriving tomorrow.  If it doesn't work (a) I will return with an update, and (b) you will probably hear the cursing from wherever you are.
Message 3 of 6
All Replies
Guru
Re: RBR50
Yes. The RBS40V-v2 will work with the RBR50
Message 2 of 6
CrimpOn
Guru
Re: RBR50
  • Extender mode
  • Orbi mode
Message 3 of 6
Toeknee72
Re: RBR50
Thanks I appreciate it
Message 4 of 6
Toeknee72
Re: RBR50
Thank you for your help!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 5 of 6
Mstrbig
Master
Re: RBR50
On sale for $99.00 free shipping
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1432 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
