Orbi WiFi 7 RBE973
Reply
RBR50v2 - No Internet
ajredaelli
Tutor
I just bought the RBR50v2 Router with a Satellite. I went ahead and setup the router. I have a strong signal, however, I wasn't able to connect with my phone. When I tried to connect my Roku and the Amazon TV - same result. Eventually I received a "strong signal" message, but I also received a No Internet Connection  Available message.   By the way, Amazon TV says "Signal Strength; Good" "Connected with problems" Security "WPA2 PSK"
What am I doing wrong?
Thank you for any assisstance.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 8
Dannyv
Re: RBR50v2 - No Internet
Having the same problems since the new update today
Message 2 of 8
CrimpOn
Guru
It is usually a good idea to know what the Orbi WAN (yellow) jack is connected to.  (specific brand & model)
and, how did you set up the Orbi router (Orbi web interface with a web browser or the Orbi "app"?)
Message 3 of 8
Guru
Is the Orbi system operating in Router or AP mode?
Message 4 of 8
ajredaelli
Tutor
I used the app to connect it.
Message 5 of 8
ajredaelli
Tutor
I will check into all of these. I can't right now because I work from home and I am not connected to the Orbi. Not sure about the firmware. It's about 1900 Sq. Ft home. Not connected to the satellite yet. When I checked it I was literally next to the Orbi and the TV was just about 20 feet away.
Message 6 of 8
Guru
Ok, check the suggestions when you get a chance.
Message 7 of 8
ajredaelli
Tutor
Will do - thanks!
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 898 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
