wlmason2
Feb 16, 2022Aspirant
RBR50v2 and RBS50v2 with Global Protect - crashes Satellite
Since upgrading to corporate Global Protect VPN, I experience shutdown when hardwired or WiFi connected to RBS50v2 Satellite with V2.7.3.22 firmware. I have no idea how to troubleshoot or remendy the situation. this does not seem to impact the router, just the particular satellite to which my laptop is connected. A satellite restart is required to get the connection working again.
Has anyone gotten Global Protect working on RBS50v2 / RBR50v2 in the current firmware?
MacBook Pro (Intel) Monteray
Macbook Pro (Intel) Bug Sur
Might contact the Global protect VPN support to see if they have any help and information regarding there product.
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi (RBK10, 20, 30, 40 and 50 Series). Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you. - CrimpOnGuru - Experienced User
(To make sure we are talking about the same thing)
The subject regard this VPN solution:
https://www.paloaltonetworks.com/products/globalprotect
The corporate office has implemented Global Protect and you are attempting to connect to it from home with MacBooks running the Global Protect VPN software?
- wlmason2Aspirant
Yes, that is correct
