luchome's avatar
luchome
RBRE960 outdoor satellit
Hallo,
In my home I operate an ORBI RBRE960
I need an outdoor satellite which has to be connected via cable (Backhaul + PoE).
It needs absolutely to be connected via cable because because the Orbi's signal reaches not the outside because of the immense wall.
What device should or can I buy?
Thanks
Luchome
1 Reply
  • DamianM's avatar
    DamianM
    NETGEAR Moderator
    Dear Customer,
    You have contacted the German-speaking NETGEAR Community.
    We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
    Kind Regards,
    DamianM
    NETGEAR Community
