Orbi WiFi 7 RBE973
Reply
RBS 20 Power Light is solid amber after turning it on.
Fvog30
Follower
Hi
I have two RBS20 satellites that after a year of use, are not working. Both of them, when turned on shows a solid amber Power Light even when I try to Reset them. Can somebody help me with this?
Message 1 of 2
Guru
Re: RBS 20 Power Light is solid amber after turning it on.
Does pressing the reset button for 15 seconds then release then wire connect a PC to the back of the RBS and wait about 5 minutes then open a web page to 192.168.1.250 result in anything?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 557 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
