Orbi WiFi 7 RBE973
Reply
RBS20 Satellites - momentary magenta
fmalloy
Luminary
Brand new RBR20 with 2 RBS20 satellites. Installed yesterday, worked fine. Both satellites have Good backhaul status. Things looked stable so this afternoon updated firmware to V2.5.1.16 using manual update via wired computer to router. Updated satellites first, then router. All went well. About three hours later, music stops streaming and multiple devices lose Wi-Fi connection. I see the nearest satellite turn magenta, about 20 seconds later magenta goes out and Wi-Fi reconnects.
I have no idea why this happened or if this will happen again, but not happy. I just came from a Nighthawk R7000 that dropped Wi-Fi randomly all the time.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 10
Guru
Re: RBS20 Satellites - momentary magenta
Message 2 of 10
fmalloy
Luminary
Well, it's happened again. Woke up and saw both satellites had a blue light, which means they must have just gotten reconnected. It seems to be a momentary loss of connection as they do come back and the clients are reconnected.
Since I saw both satellites disconnect/reconnect does it imply a problem with the router? If the router loses internet connections do the satellites go magenta or is that a separate connection?
Trying to figure out what is wrong. It's highly intermittent. Looks like it's happened about 3 times in the past 3 days.
Message 3 of 10
fmalloy
Luminary
To try to answer the questions (admittedly they are generic):
About factory reset - wouldn't that put the firmware back to the shipped version, undoing the latest firmware install?
I have no idea what the make/model of the modem is. It resides in the attic connected to the dish antenna on my roof. It has been very solid. Would the modem impact router-to-satellite communication?
House is 2400 sq. ft. Distance is about 30 ft between the router and sats. It's a triangle pattern.I get a blue light when i connect the sats.
I am using Auto channel and default 5GHz. Would that impact communcation to the sats?
Yes, I have multiple neighbors nearby. I can see sometimes >10 other Wi-Fi APs from my neighbors.
I had Fast Roaming on but turned it off. Still lost connection. Would the others really matter for a router-to-satellite connection drop?
It is very solid, but the connection infrequently and randomly drops momentarily, then reconnects.
Message 4 of 10
fmalloy
Luminary
It appears the cause of the satellite disconnections is the router rebooting itself. I noticed the satellites reconnecting at about 8AM, and I checked the SHOW STATISTICS at 4pm and the System Up Time is about 8 hours, which would make it restarted at 8AM.
The question is - why is the router rebooting itself?
I dumped my R7000 for rebooting itself. This seems like a big coincidence - could a modem problem cause the router to reboot itself? My modem is in my attic, connected to a dish antenna that beams internet to a repeater (microwave) so I don't have easy access to the modem.
Message 5 of 10
Guru
NO!
House is 2400 sq. ft. Distance is about 30 ft between the router and sats. It's a triangle pattern.I get a blue light when i connect the sats. RBS top ring LED should turn fully OFF after a short period of time being on BLUE.
Can you see what channels they are using? This maybe a factor why you maybe seeing odd issues with RBS.
I had Fast Roaming on but turned it off. Still lost connection. Would the others really matter for a router-to-satellite connection drop? To test this, disconnect the LAN cable from the RBRs WAN port. Then look at the RBS. RBS I believe should not show PINK.
Message 6 of 10
fmalloy
Luminary
When the RBS spontaneously reboots, it turns white, then pulses white for a while, then goes out when it's done rebooting. It doesn't turn blue, the satellites do that.
Unfortunately i cannot. With my R7000, I changed the channels to avoid interference. When I had interference, I would have Wi-Fi issues but it would not reboot. I will try to play with the channels.
Not sure I understand this - when I disconnect the cable from the WAN port, it turns pink because there is no internet connection; I think it's supposed to do that, right?
I have to believe I have a bad unit. Sometimes it reboots after 24 hours, sometimes after a few hours. It's random.
Message 7 of 10
Guru
Do the RBS turn PINK when you disconnected the WAN cable? Just checking this. They shouldn't.
Something to contact NG support about and see about additional help and information.
IF you've updated FW, factory reset everything and you still see this issue, i'd check with NG support.
Message 8 of 10
Iknowbetter
Zero help
Message 9 of 10
Guru
Any progress on this?
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1023 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
