Reply
RBS20 firmware version
KitchSB
Currenltly using 2.5.1.16 and check for upgrade on orbilogin says none available.  But Netgear website says current download version is 2.6.1.38.
Should I manually upgrade
Why does orbilogin not suggest new version?
Message 1 of 3
Accepted Solutions
Guru
Re: RBS20 firmware version
NG hasn't put the newer up on there auto update servers is all. You can update as well. Seen some users post having problems with recent versions of FW. You can manually download and manually update your system if you want to.
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co...
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelli...
If you choose to update, update the RBS first then RBR lastly. I would perform a reset on the system and setup from scratch after loading FW if you notice problems after the update is applied.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 3
All Replies
Guru
Message 2 of 3
KitchSB
If some users having trouble with new FW, should I wait until formally release on orbilogin?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 213 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
