Orbi WiFi 7 RBE973
Reply
RBS20 satellite required - no stock
MickC1
Hi all,
I have the standard Orbi RBS20 system. 1 Router 1 Satalite.
I want to add 2 more satalites and use cat 6 backhaul.
Unfortunately, there is no RBS20 stock availble.
So my question is will the newer satalites ie RBK853 be compatable with the system.
If no what can I do?
Thanks
MickC1
Message 1 of 2
CrimpOn
Guru
Re: RBS20 satellite required - no stock
@MickC1 wrote:
Hi all,
This is correct: stock of the original Orbi satellites is almost non-existent.  One product that IS available is the Orbi Voice RBS40V, which Amazon is selling for $100. (Perhaps as a way to coax more people into Amazon's "Alexa ecosystem" - who knows?)
You could double check that someone has verified that the RBS40V works with ethernet backhaul by posting in the Orbi Voice community forum: https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
It is pretty clear that the newer WiFi6 satellites are not compatible with WiFi backhaul to the original Orbi products.  Whether they will work over ethernet backhaul is a question that could be posted in the AX community forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Like you, I needed another satellite and the RBS40V integrated smoothly over WiFi backhaul with my RBS50 router. (The "voice" part remains a curiosity which I mostly ignore.)  If it were not mounted in a place that is awkward to take down, I would test ethernet backhaul.  Maybe someone in the Voice forum has personal experience to relate.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 285 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
