Reply
Highlighted
RBS20
Hi,
I have bought a new Orbi RBK22, it came with RBS and RBR 20. I see that the power adapter is “AC ADAPTER WITH INPUT- 100-120v - 50/60hz 0.6A
OUTPUT - 12V - 1.5A
My question is - I will be carrying this to India where the input voltage is 240v. Can you pls. Help me finding a power adapter something with 100-240v otherwise I need to return this back.
Thanks
Model: RBK22| Orbi AC2200 Tri-band WiFi System
Message 1 of 5
Highlighted
Guru
Re: RBS20
You might contact NG support to see if they offer any 240v adapters. Orbi bought in USA do not come with 220-240v adapters. Check to see if this orbi is supported in India as well.
@Sangakirankumar wrote:
Hi,
OUTPUT - 12V - 1.5A
Thanks
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK50 v2.7.0.70(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 5
Highlighted
Re: RBS20
Thanks for your reply.
I did spoke to NG technical support person and he mentioned to search online for 240v power adapter. I think I need to return the product if I dont fine any.
Message 3 of 5
Highlighted
Guru
Re: RBS20
Check places like Amazon. Good Luck.
Message 4 of 5
Highlighted
Re: RBS20
I have used Netgear 100-120 Volt adapters in 240 volt sockets. They work fine.
My theory is that they use those labels for regulatory reasons.
But do this at your own risk! Don't blame me if it goes bang. But you won't have lost anything useful.
Is there a model number on the adapter? The AD2076F10 didn't blow up on me.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 775 views
  • 0 kudos
  • 3 in conversation
Announcements
