- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS40V touch controls not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear Community,
I am facing a problem with RBS40V-200 and the control panel stopped working just in beginning of the pairing process with the orbi router.
The controls have worke initially, when I unboxed the device and started syncing it with the Orbi network I think it must have downloaded in some kind of a firmware update and the controls are no longer available. I have been on a phone with the NG support, the device has been manually upgraded to V2.5.1.4 I but that didn't resolve the issue.
Apart from that the device works well, connected as a satellite to RBR50 that runs firmware 2.5.1.16
Is there anything you could recommend that I do to bring the volume control back?
Thanks in advance!
Michal
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS40V touch controls not working
I have the same problem with my new RBS40V voice satellite. No touch control after adding satellite to RBR40 router. No lights on top except for the ring and no touch control. Alexa works though. Tech support could not help. I updated firmare from 2.5.1.2 to 2.5.1.4. but problem is still there. Is any Netgear tech person reading this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is a newer firmware V2.5.1.6. Also is the RBS40V in Orbi mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the tip about the newer firmware for the RBS40V. I upgraded it to V2.5.1.6 but this did not help. Wifi is connected and Alexa works but the touch control on top is still not working for volume, mute, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Find the IP address of the orbi voice. in your browser type 192.168.1.xx<- the ip adress/debug.htm, example 192.168.1.15/debug.htm and try Upgrade Touch Board Firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It worked! The touch control/lights are working now. Thank you so much for the solution. Hopefully I would not have to do this frequently.
@Mstrbig wrote:Find the IP address of the orbi voice. in your browser type 192.168.1.xx<- the ip adress/debug.htm, example 192.168.1.15/debug.htm and try Upgrade Touch Board Firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Desert_Dave wrote:It worked! The touch control/lights are working now. Thank you so much for the solution. Hopefully I would not have to do this frequently.
Great please mark as solution so others can benefit from the results
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you have a fix on this issue? I have the same problem with MyBalanceNow
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Parha1m wrote:Did you have a fix on this issue? I have the same problem with MyBalanceNow
Did you try?
- Mark as New
- Bookmark
- Subscribe
- Permalink
the solution has already been shared
- Mark as New
- Bookmark
- Subscribe
- Permalink
