- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS50 Broadcasting Slow WiFi Signal, but Hardwired Works Great?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBR50/RBS50 system. The RBR50 is in the middle of the house and wifi speeds when near it are great with any decvice.
However, RBS50 in my office has very slow wifi speeds, even when I have it sitting on my desk right next to my Macbook. When I connect my Macbook directly to the RBS50 with an Ethernet cable, the speeds are great so the RBR50 has a strong connection to the RBS50.
I have rebooted and and tried all kinds of things and I cannot seem to get the RBS50 to have a fast wifi. Because the speeds of the RBS50 are strong when hardwired but weak when cnnecting wirelessly, does that mean I may have a defective RBS50? If it helps, I purchased the system in May of 2017 and hasn't always had this problem.
Any help is appreciated!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 Broadcasting Slow WiFi Signal, but Hardwired Works Great?
After looking into your suggestions, I did a complete factory reset and reset it up from sctratch seemed to do the trick.
Note that I did a factory reset not by pushing the little button on the back with a paperclip (I tried that a few times), but going into the router settings, clicking on Advanced > Backup Settings > and hitting the Erase button under "Revert to Factory Default Settings".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Awesome. Glad that it's working now. Pressing the button in back for 15 seconds then release should work as well.
Enjoy,
