Orbi WiFi 7 RBE973
Reply
RBS50 Does not connect to Internet
Yatheesh
Initiate
Hi,
I have a RBR50 Orbi modem with RBS50 extension satellite.  Since morning,  RBR50 base station is working fine and provides internet connection to attached devices, however satellite does not. Both the were working perfectly fine till yesterday. Both are using version 2.7.3.22 firmware.  Satellite is connected to basestation(conencts with solid blue light). I tried doing a factory reset for satellite. But still it does not work. My basestation is in ground floor and satellite is in first floor. My house size is  120SQM in GF and same in first floor.
Apprecaite help.
Model: RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 1 of 2
Guru
Re: RBS50 Does not connect to Internet
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Be sure the RBS FW is updated to same version as whats loaded on the RBR.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 352 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
