- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS50 Firmware Version 2.3.0.32
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good day everyone
Should I upgrade to RBS50 Firmware Version 2.3.0.32 manually or would it be upgraded automatically as it always does.
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It will upgrade automatically when Netgear decides that they are confident that an automatic update will not cause a flood of problems. Right now, numerous Orbi customers are doing a manual update (a) because they have an Orbi issue and hope the upgrade will fix it, or (b) because they like to live "on the bleeding edge." (I upgraded even though my system is "just fine.") There is a chance (slim, but still a chance) that Netgear will decide not to release this firmware and will go "back to the drawing board" with further work. In that case, there will be another Beta and another period of manual update.
"If it ain't broke, don't fix it." One day you will find that Orbi updated all by itself.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 Firmware Version 2.3.0.32
Thanks for the reply. I think i'll wait. It aint broken so there's no reason to fix.
Thanks again
